Clears the counters for the DAD feature.
vr_name |
Specifies a VR for which to clear the counters. |
ipaddress |
Specifies an IPv6 address for which to clear the counters. |
vlan_name |
Specifies a VLAN for which to clear the counters. |
If you do not specify a VR or VRF, the command applies to the current VR context.
The vr all option clears the DAD counters for all IPv6 interfaces on the switch.
This command clears the DAD failure counters and removes the MAC for the conflicting IPv6 address after the duplicate address condition has been resolved. The DAD counters and saved MAC addresses are not automatically cleared; they must be cleared with this command.
The following command clears the DAD counters for all IPv6 interfaces in all VRs:
clear ipv6 dad vr all
This command was first available in ExtremeXOS 12.6.
